First attempt at a Water Injection table....opinions please.
GPO duty cycle will be % ouput of the WI pump. Not sure of the nozzle size yet.
Re: First attempt at a Water Injection table....opinions ple
Looks like a solid graph (mimicing the boost curve, it appears, as it should). I have two questions though.Duke M535ti wrote:
1) Did you calculate the maximum water flow-rate using the latent heat of vaporization and how much can and will actually be fully vaporized with your boost level, engine size, and intake temps... or is it an arbitrary value you just picked?
2) What program is that on? That's a really slick WI control setup!!
I can't wait to see the before and after dyno pulls!
I think there are two issues here; 1) the amount of water able to be vaporized in the intake tract as a function of a) H2O nozzle design/placement, b) intake charge temperature, c) boost pressure, and d) intake charge velocity and 2) the amount of water that can be injected into the cylinder before BMEP deteriorates.
If the goal is to cool the intake charge and forestall detonation, it should be possible, given the placement of the water injection nozzle and particle size of atomization, to arrive at how much water can be vaporized given a particular pressure/temperature/velocity fact pattern.
If the goal is to cool the engine/combustion chamber through water injection beyond the maximum amount of water able to be vaporized by the intake charge, then in this case, I believe water injection at the intake port or cylinder is the only way. Individual injectors can atomize sufficient water into the intake ports/combustion chambers. Injecting that quantity of water anywhere but the intake port or cylinder will result in water falling out of suspension and reduced cooling…
Kudos on all the great results you're getting Duke!!!
http://ausrotary.dntinternet.com/forums ... hp?t=38929
rx7 guys are haveing a big feud over water vs alcohol injection, they both work really well....
mike
mike
