FMIC without any cutting!
Jays535is
Post by Jays535is »
So I had this FMIC from a Gen 3 Rx7 that came with my car exactly like this.
http://cgi.ebay.com/ebaymotors/Mazda-RX ... enameZWDVW
I was originally going to use an air/water unit, but after starring at it long enough I figured I could get this intercooler in there with minimal modification.
I removed the a/c fan, and bottom fan mount. Then I manipulated the brackets so the condensor was closer to the radiator (about a 1/2 inch). Then slide the intercooler in from the bottom, it's very snug in there without any actual mounting. The inlet & outlet are facing the firewall. I will be using my a/c so I will install 2 smaller fans above the intercooler.
turbodan
Post by turbodan »
You're going to need more cooler than that. Thats smaller than my primary air/air, which produced 150 degree charge temps at the top of second gear. That'll kill your power in second gear on up.
Jays535is
Post by Jays535is »
turbodan wrote:You're going to need more cooler than that. Thats smaller than my primary air/air, which produced 150 degree charge temps at the top of second gear. That'll kill your power in second gear on up.
I agree with you about the size. Although your probably running more boost then I'm going to (about 8 psi). I just figure it's alot better than no intercooler, and alot easier and cheaper than an a/w unit.
SilverBullet
Post by SilverBullet »
http://www.siliconeintakes.com/
There's some cheapish ones on there, whether they'll do the job or not i dont no.
Shawn D.
Post by Shawn D. »
SilverBullet wrote:... i dont no.
So, you're a "yes man"? :laugh:
turbodan
Post by turbodan »
Jays535is wrote:I agree with you about the size. Although your probably running more boost then I'm going to (about 8 psi). I just figure it's alot better than no intercooler, and alot easier and cheaper than an a/w unit.
You'll be turning it up sooner or later, I assure you. Its a nice bonus down the road, when you've got the tune down at like 12 psi, and all you have to do is get a larger intercooler for a massive gain in performance.
Are you going to use any data acquisition system to watch your IAT's?
Jays535is
Post by Jays535is »
Are you going to use any data acquisition system to watch your IAT's?[/quote]
Eventually. Later down the road I might use a water/methanol injection system also. I also will be fabbing up some shrouding to force all air coming threw the openings to go threw the intercooler.
T_C_D
Post by T_C_D »
That's absolutely the least efficient way to have the air enter the tanks. Tanks are a nice design but entry into the tanks is as bad as it gets.
The core size is sufficient for 8psi.
Jays535is
Post by Jays535is »
T_C_D wrote:Image
Definitely not ideal, but it came with the car. I do have an eBay a/w unit that I could use. Or I could get the in/outlets re-welded for a smoother transition.
