SOLD
BAVARIANUT
Post by BAVARIANUT »
AFM sold. :D
BAVARIANUT
bump
e34 530
Post by e34 530 »
If you lift up the shift boot, there is a black rubber "boot" that blocks heat, is it in good shape?
BAVARIANUT
e34 530 wrote:If you lift up the shift boot, there is a black rubber "boot" that blocks heat, is it in good shape?
i believe so, I know that the foam was shot, but I'll check.
DOUGBARTEN
REAR DIFFERENTIAL
Post by DOUGBARTEN »
IS THE REAR DIFFERENTIAL STILL AVAILABLE?
REGARDS,
DOUG BARTEN
BAVARIANUT
Re: REAR DIFFERENTIAL
DOUGBARTEN wrote:IS THE REAR DIFFERENTIAL STILL AVAILABLE?
REGARDS,
DOUG BARTEN
sold, sorry. No need to yell. :D
The Baron
Post by The Baron »
Don't have 160mm wide foglamps, do ya?
BAVARIANUT
The Baron wrote:Don't have 160mm wide foglamps, do ya?
nope, sorry.
ismellfish2
Post by ismellfish2 »
BAVARIANUT wrote:
dinanm3atl wrote:
BAVARIANUT wrote:
dinanm3atl wrote:Still have the sport springs/bilsteins?
Coming off the car yet?
Yes, Are you local?
I don't know what the nutmeg state is but I doubt it is Georgia ;)
Connecticut, pending sale on G265 tranny, ecu sold.
Many parts still available. unfortunately suspension bits are staying on the car, but anyone local with a wheel doly can have the rest of the car for a good price, once i'm done unbolting the rest of the removable parts.
Bilstein H.D. struts, Bavauto springs,
near new H.D. upper/lower control arms, tie rods inner/outer, brand new tires on 14" bottlecaps will stay on the car for sure.
Did you end up selling the 265? I still need a bellhousing.
BAVARIANUT
ismellfish2 wrote:
BAVARIANUT wrote:
Yes, Are you local?
no, I plan on selling the bellhousing with the tranny, but if the buyer doesn't need the bellhousing, its yours.
the original buyer is out at sea in service right now and won't return for a few months, but by then I expect it to be sold, but who knows.
garrettm
Heater Valve
Post by garrettm »
Do you still have the heater valve available? I have a 1984 e28 I just inherited and the heater valve cracked on the inlet (So it's now undriveable). I assume that the one from the 1985 is identical. I can post pics of mine if need be. Also, what would the price be.
Thank you very much.
Garrett M
e34 530
Post by e34 530 »
Ever checl on the black rubber guard?
BAVARIANUT
Re: Heater Valve
garrettm wrote:Do you still have the heater valve available? I have a 1984 e28 I just inherited and the heater valve cracked on the inlet (So it's now undriveable). I assume that the one from the 1985 is identical. I can post pics of mine if need be. Also, what would the price be.
Garrett M
Heater valve was bypassed along time ago. It has since been trashed.
Huh?
BAVARIANUT
bump; last set of fuel injectors sold, inline fuel pump sold.
Soco
Post by Soco »
umm, do you have a pair of 4x6's from the front? did they fit in the stock location? price?
thanks
BAVARIANUT
Soco wrote:umm, do you have a pair of 4x6's from the front? did they fit in the stock location? price?
thanks
no 4x6, just whats pictured. only the tweeters fit in stock mounting location/size.
e34 530
Post by e34 530 »
Did you ever check on the rubber heat boot under the shift boot and do you still have the fuel pressure regulator?
contor
Post by contor »
pm'd
BAVARIANUT
e34 530 wrote:Did you ever check on the rubber heat boot under the shift boot and do you still have the fuel pressure regulator?
Yes I have the fpr. Oh ya, I'll check the boot. Does it come out from the top, inside the car?
BAVARIANUT
i still have FPR, the rubber on the shift area is shot.
jrmartin
i need parts bad
Post by jrmartin »
pmd ya
e34 530
Post by e34 530 »
Damnit, didn't see this post or i would have bought the FPR from ya. Do you have the round brake light switch under the driver kickpanel, I need one asap.
BAVARIANUT
bump, tweeter pods sold.
i'll check on the round brake light switch, e34 530
e34 530
Post by e34 530 »
BAVARIANUT wrote:bump, tweeter pods sold.
Thanks, also can you check my thread for any of this crap, I'd be willing to buy it all for like 20 bucks or something plus shipping:
http://mye28.com/viewtopic.php?t=49599
BAVARIANUT
bump
I didnt bother to sift through 5 pages. Is the RF fender in good shape?
BAVARIANUT
a wrote:I didnt bother to sift through 5 pages. Is the RF fender in good shape?
You don't need to shift through all those pages. what I have is pictured. As seen in photos, Paint is ok for the age. just click the image for an enlarged view, thanks.
BAVARIANUT
bump
quasi
Post by quasi »
pm sent
BAVARIANUT
bump.
