Page 9 of 10
Posted: Apr 14, 2010 12:47 PM
by turbodan
bornagain wrote:well the injectors were for the big picture which i have not gotten to just yet but am getting there. As for the enrichments, i was having alot of problems with noise in the wiring, that is why i have a brand new 12' foot diyautotune wiring harness with all new connectors. I have a few other plans, including new fuel pump and new regulator running atleast a 3 bar reg. And it is just richening up at the high end which i knew about but couldnt change as my friend had borrowed my tuning cable and i dont run the car that hard very often.
You would most likely be better off with the stock harness unless its beyond repair. What you're attributing to noise is more likely be due to improper settings in Megatune or bad grounds. The stock loom is very well shielded where needed. I do just fine with the stock wiring.
Notice how it seems to be dropping a fixed percentage of your PW? That says "its in your settings". I dont see any significant noise in the RPM, MAP or coolant/air temp readings.
Posted: Jan 03, 2013 7:10 PM
by WildKarrde
Just got done reading the thread, cool project!
Posted: Jan 03, 2013 9:19 PM
by Brad D.
Wow, I haven't seen this thread in a while. A quick update which isn't very exciting - the car is running well at 12psi and has been since this thread was updated. It's crazy to think that the last post in this thread was 2010. Time flies when you are having fun.
Posted: Apr 07, 2013 6:15 PM
by thrty8street
What are the lengths of the oil feed and oil return lines? ( I am also doing a top mount build)
Posted: Apr 18, 2013 10:08 AM
by Brad D.
thrty8street wrote:What are the lengths of the oil feed and oil return lines? ( I am also doing a top mount build)
I want to say my feed line is 36" +/- a couple of inches. My return line has a flexible teflon lines stainless line that is about 8" long with a couple of inches of stainless tubing connected by Swagelok fittings. Hope that helps.
Posted: Apr 18, 2013 11:23 AM
by Coldswede
Brad D. wrote:Wow, I haven't seen this thread in a while. A quick update which isn't very exciting - the car is running well at 12psi and has been since this thread was updated. It's crazy to think that the last post in this thread was 2010. Time flies when you are having fun.
Brad did you ever put that new clutch in? If so we need a report on how you like it .
Posted: Apr 18, 2013 4:40 PM
by Brad D.
I did finally put the clutch in last summer. It has been great. Pedal feel is basically like stock and engagement isn't touchy at all. All in all I would highly recommend that clutch for anyone wanting great driveability with good holding power.
build
Posted: Feb 08, 2014 5:49 PM
by dakal
a great build. lots of info for my future build.
Posted: Feb 12, 2014 12:32 PM
by GrayGohst
Good read. :)
Re: My 535is Turbo Buildup Thread! - update 11/26//09
Posted: May 17, 2015 11:26 PM
by daniels635turbo
What no video!!!
Posted: Jul 20, 2016 8:44 AM
:popcorn: waiting on the report from the new steward.
Posted: Jul 20, 2016 9:10 AM
by M. Holtmeier
I'm lost.
Posted: Jul 20, 2016 11:01 AM
by T_C_D
M. Holtmeier wrote:I'm lost.
Apparently Brad sold it.
Posted: Jul 21, 2016 4:21 AM
Posted: Jul 27, 2016 3:28 PM
by Nebraska_e28
I rode in this several years ago while visiting the area. One hella fast car!!!
Posted: Jul 20, 2017 6:19 PM
by BobBomb
Wish I could see all the pics. Use Flikr instead it lets you post third party pics without paying.
Posted: Aug 01, 2017 9:30 PM
by M. Holtmeier
BobBomb wrote:Wish I could see all the pics. Use Flikr instead it lets you post third party pics without paying.
I know, he had like ten years to update. Right?
Posted: Aug 06, 2017 6:25 PM
by Shadow
i was told by some members that brad is not modding cars anymore and drives a 14 accord.
Posted: Aug 12, 2017 11:53 PM
by M. Holtmeier
RIP, Big Bronze Rims.
Posted: Oct 02, 2017 10:23 AM
by Brad D.
Hey guys, I will try to update all the pics. Life and work have been crazy and haven't had a lot of time to post. I got images rehosted but have to update all the links which will take a bit of time. Hope everyone is doing well.
Posted: Oct 02, 2017 10:55 AM
Good to see you're still kickin'.
Posted: Oct 02, 2017 11:02 AM
by Brad D.
1st 5er wrote:Good to see you're still kickin'.
Still kickin'! Just had a lot on my plate with new work responsibilities and the kids growing up with things like sports and other school commitments.
And to dispel any rumors, I haven't stopped tuning cars and definitely don't drive a '14 accord. Lol.
Posted: Nov 17, 2017 9:30 PM
by M. Holtmeier
Hi Brad, I'm glad you're still around and doing well!
Posted: Nov 17, 2017 11:56 PM
by Nebraska_e28
Good to hear from ya Brad! That was one fast azz 5 you built. I'll get there one day.
Re: My 635is Turbo Buildup Thread! - update 11/26//09
Posted: Apr 24, 2018 8:36 PM
by mintus
Hello All; I have a 1986 m30b34 turbo 635 and I have a rusted 1989 635 with a m30b35 engine, so what I have understood is that the head off the b35 may or may not add to my HP addition.
I wish to swap the heads and put my turbo cam in the b35 and hope Bob is your uncle.
I am open for any points of view pro or con if you can be so kind.
Thanks;
Brian
