Posted: Mar 07, 2005 2:25 PM
by Jon in Richmond
Posted: Mar 07, 2005 2:38 PM
by MarkD in NJ
I believe they use the same pads as a 2002 or an E12 5-series. Not an upgrade on the E28 as pad area is quite a bit smaller.
Posted: Mar 07, 2005 5:28 PM
by Kenny Blankenship
I think an E12 is it, not sure about a 2002. The spacing between the bolts that mount the calipers is different from an E28, that's why upgrading the E23 is nearly impossible.
Posted: Mar 07, 2005 6:23 PM
by Velocewest
Bolt spacing is the same as e12 and earlier, can't say for e28. Centering on the rotor may vary. Won't fit 2002 or e21, bolt spacing is different. Only a single inlet, so they are not a bolt on for e12 or earlier which use dual line fronts.
Basically, they're good for e23's...
As far as pad size, mefinks you be high, mon -- e28 pads are not much if any larger than e12 pads, just a different shape.
[Edit by Velocewest on [TIME]1110238145[/TIME]]
Posted: Mar 08, 2005 2:25 PM
by MarkD in NJ
OK...so I'm wrong on pad surface area. It feels good, though, since I'm probably really high!
Posted: Mar 08, 2005 2:42 PM
by Velocewest
[QUOTE="MarkD in NJ"]OK...so I'm wrong on pad surface area. It feels good, though, since I'm probably really high![/QUOTE]
Daht's dah spirit, mon! 'Tis always bettah to be high, daht's nevah wrong!
