Idle is terrible…need help(tooth angle??!!??)
I have my pnp system modded in. I’m using the b35m30 dampner wheel and the e28 goodies sensor and mount. The sensor is not in the same place as stock sensor was obviously. I THINK MY TOOTH ANGLE IS INCORRECT. NOT SURE HOW TO CALCULATE IT. I get the car started but it revs real high and sputters and dies when throttle input is made. Anyway CAN SOMEONE TELL ME HOW TO SET UP A PROPER TOOTH ANGLE WITH MY SET UP.
Re: Idle is terrible…need help(tooth angle??!!??)
I didn't realize your sensor is in a different location. You're gonna need to read and understand this.
http://www.megamanual.com/ms2/wheel.htm
Basicaly each tooth is 6 degrees
Thanks, I got the tooth angle figured out…..now I’m just trying to get the tune right. Anyone know where I can get a nice tune for a m30 with 30lb injectors..?!?
