Turbo tuning with SAFC-II and LM-1 on the M30b35..
russc
Post by russc »
Gents,
Ive been doing some datalogging with my system the last 4days. The results are very exciting. Pretty happy with the setup...to a point that I have it runing right now.
First, I haven't come up with a fault code in 3 days now. The 179 ECU needs to see the air metering device in certain voltage ranges for WOT. I had the AFM spring too tight and the ECU would throw a 1215(AFM error) after the first long WOT run. Some lossening of the spring 5 clicks from Dinans setting and bang, no more errors.
This makes sense, as Im running ~35% less air mass with this system since Im running 8.5psi with this M30b5 vs 13psi on the M30b34.
Also, I solved alot of my pre-detonation issues with the TCD software for the 179 ECU. While its not completely gone, Im able to run w/o pre-det on select runs. My real trouble still comes in the 4.5k-6k rpm range, where the J&S knock controller cant control timming. The TCD chip is still too timing aggressive in the upper rpm range @ 8.5psi with 91octane CA crap formulation gas. Im sure that TCDs software is tuned for 94octane pump Sunoco. Im sure if I had 94 in this puppy, it would run 10psi easy.
So, on with the data log.
First is the 4th gear run...
The green trace is the throttle signal. I was able to dial in the AFRs very well with the SAFC-II. Essentially Id make a run, look at the log, change the SAFC and make another run. After ~ 8runs, that where Im leaving it. I can't run any higher AFRs with 91octane. Also, w/o the ability to adjust timing in the upper rpm range, Im stuck with ~12:1.
Heres a 3rd gear run to a higher rpm...
Again, AFRs are pretty nuts on for my system.
What is nice about this, I can estimate what hp this system is making by the AFM voltage. I believe as long as the AFM voltage is increasing, the car is making more power, as its taking in more air 8)
Plus, I can gauge if mods are making more power by the peak AFM voltage w/o having to run dynometer runs. Once I know what AFM voltage is making what power, you plot hp to AFM voltage and see right away what the changes are doing :beer:
So there it is. Im happy with the results. If only I could get 94 at the pump here, oh my.....
RussC
