Page 1 of 2
stock ecu with more punch?
Posted: Apr 29, 2007 7:53 PM
by rs4pro3
Doesn't look to different from the outside
Oh wait there is something else lurking inside
MS v3.0 running full spark and fuel setup for a stroker m20
It's in my e30 and running right now, 98% plug and play(have to add a TPS, and rewire the main relay to not be controlled by the ecu. Had to change the DB37 plug out for a vertical one, that way you can unplug the motronic connector and plug the stim in for testing etc...
Posted: Apr 29, 2007 7:58 PM
by Kyle in NO
Excellent!!! A friend is building my MS right now to be housed inside a stock Motronic box, like yours. I thought I was gonna be the first with a setup like this!
Its gonna be real nice to have a plug and play unit for the factory harness isn't it? Great job!
Posted: Apr 29, 2007 8:03 PM
by vance
Very nice!
Vance
Posted: Apr 29, 2007 8:18 PM
by rs4pro3
yep plug and play is wonderful. I've been selling adapter harnesses to some e30 guys for a while with the motronic plug on one end and the MS on the other end, but decided to go all out on mine. Kyle I'm not sure if you're friend will be able to utilize the stock DB37 plug, I couldn't get the lid back over it and keep all the wires internal with it.
Posted: Apr 29, 2007 8:38 PM
by vance
Pardon the ignorance, but what is the DB37 plug?
Vance
Posted: Apr 29, 2007 8:41 PM
by rs4pro3
It's the main connector plug for the megasquirt ecu. It's a d-sub connector with 37 pins.
Posted: Apr 29, 2007 9:59 PM
by vance
Thanks for clearing that up.
Vance
Posted: Apr 30, 2007 8:14 AM
by altus22
Nice work! I want to do this for a friend in an L-jet box. Glad to see getting the BMW connector off isn't too hard.
So are you running wasted spark or single coil? Is it controlling your IAC?
Posted: Apr 30, 2007 8:40 AM
by Shawn D.
Very cool -- nice job!
Posted: Apr 30, 2007 9:59 AM
by rs4pro3
I'm running just the stock spark, eventually I plan on going to wasted spark, No idle control, stock idle valve is still in place on engine and it idles rock solid without any control(just crack the TB open a tad).
Posted: Apr 30, 2007 10:31 AM
by turbodan
That is awesome. Great work. Is this on an NA stroker?
Posted: Apr 30, 2007 11:04 AM
by M635CSi
If I understand correctly, you're using the VB921 to drive the stock coil. What crankshaft reference sensor are you using?
Congratulations on a nice clean installation!
Posted: Apr 30, 2007 1:50 PM
by rs4pro3
Ya Na m20 stroker(posted it here as it's engine management). I'm using the stock 60-2 crank wheel and VR sensor.
Posted: Apr 30, 2007 2:04 PM
by turbodan
rs4pro3 wrote:Ya Na m20 stroker(posted it here as it's engine management). I'm using the stock 60-2 crank wheel and VR sensor.
Wow. With that hardware you could support a serious turbo mill. Imagine 20 psi...
Posted: Apr 30, 2007 3:11 PM
by rs4pro3
well the main reason I went megasquirt is for a custom ITB intake I'm making for the engine 8)
Posted: Apr 30, 2007 5:20 PM
by turbodan
rs4pro3 wrote:well the main reason I went megasquirt is for a custom ITB intake I'm making for the engine 8)
Way sweet. You should still turbocharge it. That would be utterly vulgar with forced induction...
Posted: May 01, 2007 5:19 PM
by altus22
If you later decide to go with MSII/extra, you can pretty easily do wasted spark or coil on plug and IAC control. You might be able to do WS and IAC w/ just MS/extra. Just fun thoughts.
If you want to do crazy boost, some designers are selling 3 and 4 bar MAP sensors. BOOST!
Posted: May 01, 2007 5:44 PM
by Azure
As a total aside, are you doing the tuning with a Mac laptop (as I see in the pic)? How are you managing that? I thought the software was PC only.. or do you have a new Mac that can dual boot?
Posted: May 01, 2007 11:04 PM
by rs4pro3
I just got that mac laptop sunday, but have been doing tuning with a old dell laptop. You can run megatunix on a mac, but it's a very long process to install. I actually had to do very little tuning, as my friend has a stroker with similar specs that I put megasquirt on, so I just dumped in his file.
Posted: May 02, 2007 9:20 AM
by C.J.
Wait, you can run the software on a Mac? Awesome.
Posted: May 02, 2007 4:54 PM
by rundatrack
Going to put that one the wifes car later this year....
93
525 5 speed...
by rs4pro3
ya there is a unix based version called megatunix. But the install process is about a 6-8 hour ordeal as you have to download a bunch of apple developer tools, and run a bunch of scripts.
Posted: May 02, 2007 6:48 PM
by turbodan
rs4pro3 wrote:ya there is a unix based version called megatunix. But the install process is about a 6-8 hour ordeal as you have to download a bunch of apple developer tools, and run a bunch of scripts.
I thought Macs "just worked".
Posted: May 02, 2007 11:03 PM
by rs4pro3
for everything else,
Posted: May 03, 2007 2:00 AM
by ///ARINUTS...
rs4pro3 wrote:I'm running just the stock spark, eventually I plan on going to wasted spark, No idle control, stock idle valve is still in place on engine and it idles rock solid without any control(just crack the TB open a tad).
If you are running stock spark, don't you need to retain some of the factory components of the ECU. I see all MS stuff in there.
and how many stock sensors did you save?
Posted: May 03, 2007 3:43 AM
by Azure
turbodan wrote:rs4pro3 wrote:ya there is a unix based version called megatunix. But the install process is about a 6-8 hour ordeal as you have to download a bunch of apple developer tools, and run a bunch of scripts.
lol. Maybe if it was Mac software you were installing and not unix software, sure!
Posted: May 03, 2007 4:25 PM
by rs4pro3
no stock stuff in the ecu is needed, It is running on all oem BMW sensors. Just unplugged the 325i ecu, and maf conversion I had, and plugged the megasquirt ecu in. You just have to use easy-therm to convert the megasquirt code to read the bmw sensors correctly.
Posted: May 03, 2007 8:41 PM
by altus22
rs4pro3 wrote:no stock stuff in the ecu is needed, It is running on all oem BMW sensors. Just unplugged the 325i ecu, and maf conversion I had, and plugged the megasquirt ecu in. You just have to use easy-therm to convert the megasquirt code to read the bmw sensors correctly.
I think the confusion was that you're running motronic for spark. So you're using MS in dizzy mode?
Posted: May 03, 2007 10:56 PM
by rs4pro3
I'm running the High-res extra code, and using the wheel decoder to read the stock vr sensor and trigger megasquirt when to do spark events. No dizzy mode or anything like that.
Posted: May 04, 2007 10:11 AM
by M635CSi
This is an E30 (325i) so it's not directly applicable to a stock E28. Not sure what signal conditioning, if any, would be required to use the E28 flywheel reference sensor for spark with Megasquirt.
