stock ecu with more punch?
rs4pro3
Post by rs4pro3 »
Doesn't look to different from the outside
Oh wait there is something else lurking inside
MS v3.0 running full spark and fuel setup for a stroker m20
It's in my e30 and running right now, 98% plug and play(have to add a TPS, and rewire the main relay to not be controlled by the ecu. Had to change the DB37 plug out for a vertical one, that way you can unplug the motronic connector and plug the stim in for testing etc...
Excellent!!! A friend is building my MS right now to be housed inside a stock Motronic box, like yours. I thought I was gonna be the first with a setup like this! :bawl:
Its gonna be real nice to have a plug and play unit for the factory harness isn't it? Great job!
vance
Post by vance »
Very nice!
Vance
rs4pro3
Post by rs4pro3 »
yep plug and play is wonderful. I've been selling adapter harnesses to some e30 guys for a while with the motronic plug on one end and the MS on the other end, but decided to go all out on mine. Kyle I'm not sure if you're friend will be able to utilize the stock DB37 plug, I couldn't get the lid back over it and keep all the wires internal with it.
vance
Post by vance »
Pardon the ignorance, but what is the DB37 plug?
Vance
rs4pro3
Post by rs4pro3 »
It's the main connector plug for the megasquirt ecu. It's a d-sub connector with 37 pins.
vance
Post by vance »
Thanks for clearing that up.
Vance
altus22
Post by altus22 »
Nice work! I want to do this for a friend in an L-jet box. Glad to see getting the BMW connector off isn't too hard.
So are you running wasted spark or single coil? Is it controlling your IAC?
Very cool -- nice job!
rs4pro3
Post by rs4pro3 »
I'm running just the stock spark, eventually I plan on going to wasted spark, No idle control, stock idle valve is still in place on engine and it idles rock solid without any control(just crack the TB open a tad).
That is awesome. Great work. Is this on an NA stroker?
M635CSi
Post by M635CSi »
If I understand correctly, you're using the VB921 to drive the stock coil. What crankshaft reference sensor are you using?
Congratulations on a nice clean installation!
rs4pro3
Post by rs4pro3 »
Ya Na m20 stroker(posted it here as it's engine management). I'm using the stock 60-2 crank wheel and VR sensor.
rs4pro3 wrote:Ya Na m20 stroker(posted it here as it's engine management). I'm using the stock 60-2 crank wheel and VR sensor.
Wow. With that hardware you could support a serious turbo mill. Imagine 20 psi...
rs4pro3
Post by rs4pro3 »
well the main reason I went megasquirt is for a custom ITB intake I'm making for the engine 8)
rs4pro3 wrote:well the main reason I went megasquirt is for a custom ITB intake I'm making for the engine 8)
Way sweet. You should still turbocharge it. That would be utterly vulgar with forced induction...
altus22
Post by altus22 »
If you later decide to go with MSII/extra, you can pretty easily do wasted spark or coil on plug and IAC control. You might be able to do WS and IAC w/ just MS/extra. Just fun thoughts.
If you want to do crazy boost, some designers are selling 3 and 4 bar MAP sensors. BOOST!
Azure
Post by Azure »
As a total aside, are you doing the tuning with a Mac laptop (as I see in the pic)? How are you managing that? I thought the software was PC only.. or do you have a new Mac that can dual boot?
rs4pro3
Post by rs4pro3 »
I just got that mac laptop sunday, but have been doing tuning with a old dell laptop. You can run megatunix on a mac, but it's a very long process to install. I actually had to do very little tuning, as my friend has a stroker with similar specs that I put megasquirt on, so I just dumped in his file.
C.J.
Post by C.J. »
Wait, you can run the software on a Mac? Awesome.
rundatrack
Post by rundatrack »
Going to put that one the wifes car later this year....
93
525 5 speed...
:evil: :evil: :evil: :evil:
rs4pro3
Post by rs4pro3 »
ya there is a unix based version called megatunix. But the install process is about a 6-8 hour ordeal as you have to download a bunch of apple developer tools, and run a bunch of scripts.
rs4pro3 wrote:ya there is a unix based version called megatunix. But the install process is about a 6-8 hour ordeal as you have to download a bunch of apple developer tools, and run a bunch of scripts.
I thought Macs "just worked". :rofl:
rs4pro3
Post by rs4pro3 »
for everything else, :rofl:
///ARINUTS...
Post by ///ARINUTS... »
rs4pro3 wrote:I'm running just the stock spark, eventually I plan on going to wasted spark, No idle control, stock idle valve is still in place on engine and it idles rock solid without any control(just crack the TB open a tad).
If you are running stock spark, don't you need to retain some of the factory components of the ECU. I see all MS stuff in there.
and how many stock sensors did you save?
Azure
Post by Azure »
lol. Maybe if it was Mac software you were installing and not unix software, sure! :rofl:
rs4pro3
Post by rs4pro3 »
no stock stuff in the ecu is needed, It is running on all oem BMW sensors. Just unplugged the 325i ecu, and maf conversion I had, and plugged the megasquirt ecu in. You just have to use easy-therm to convert the megasquirt code to read the bmw sensors correctly.
altus22
Post by altus22 »
rs4pro3 wrote:no stock stuff in the ecu is needed, It is running on all oem BMW sensors. Just unplugged the 325i ecu, and maf conversion I had, and plugged the megasquirt ecu in. You just have to use easy-therm to convert the megasquirt code to read the bmw sensors correctly.
I think the confusion was that you're running motronic for spark. So you're using MS in dizzy mode?
rs4pro3
Post by rs4pro3 »
I'm running the High-res extra code, and using the wheel decoder to read the stock vr sensor and trigger megasquirt when to do spark events. No dizzy mode or anything like that.
M635CSi
Post by M635CSi »
This is an E30 (325i) so it's not directly applicable to a stock E28. Not sure what signal conditioning, if any, would be required to use the E28 flywheel reference sensor for spark with Megasquirt.
